Screen Space Ambient Occlusion
Screen Space Ambient Occlusion (SSAO) is used for efficiently approximating the ambient occlusion effect in real-time. Compared to Global Illumination, Ambient Occlusion is less accurate as it only operates in screen space, but it has its advantages. Similar to other post-processing effects like SSR or DOF, it is important that geometries are writing to the Z-Buffer. Otherwise, they won't be affected by this technique. For each pixel, the Screen Space Ambient Occlusion samples the depth values around this pixel and tries to compute the amount of occlusion on this point.
If your graphic only contains static elements, we recommend to use the Ambient Occlusion option within the Global Illumination features. The quality is much better and more accurate. For any dynamic content, you should use the Screen Space Ambient Occlusion feature.
Ambient Occlusion OFF
Real Time Ambient Occlusion
Global Illumination Baked AO
images/download/attachments/92979979/image2022-12-5_13-2-48.png
images/download/attachments/92979979/image2022-12-5_13-2-31.png
images/download/attachments/92979979/image2022-12-5_13-1-59.png
Advantages/Disadvantages of Real Time Ambient Occlusion
Advantages
Disadvantages
No pre-processing/baking required
Inaccurate
Works with dynamic objects
Performance impact
Easy to use
How to Use Ambient Occlusion
To use Ambient Occlusion, enable it in the Post Processing Effects. This is different from the Ambient Occlusion settings for the Classic Render Pipeline.
images/download/attachments/92979979/image2022-3-29_13-36-9.png
SSAO Parameters
  • Factor: Controls the strength of this effect.
  • Samples: Sets the number of rays used to gather AO information.
  • Range: Determines the maximum range of each sample-ray.
  • Threshold: Determines the threshold to remove artifacts on geometry edges.
  • Compensate factor: Compensates for edge artifacts.
  • Blur kernel: Controls the quality of the blur.
  • Blur Factor: Controls how strong the AO gets blurred.
