Chromatic Aberration
Chromatic Aberration is the effect of a defective lens where it fails to focus all colors into a single point. As cameras might show this in real life, in computer graphics this effect needs to be simulated to achieve a photo realistic look.
What happens inside the Lens can be illustrated like this:
images/download/attachments/92979989/image2020-3-19_13-34-7.png
In computer graphics, this effect is simulated to achieve an effect as if your graphic is filmed through a real camera.
Without Chromatic Aberration
images/download/attachments/92979989/image2020-3-19_13-20-11.png
With Chromatic Aberration
images/download/attachments/92979989/image2020-3-19_13-21-19.png
Chromatic Aberration is built in as a post process effect in the Viz Engine Render Pipeline.
  • Make sure you are using the Viz Engine Render Pipeline and Post Process Effects are turned on in your Scene Editor.
  • Switch to Scene settings and turn on Chromatic Aberration in Post Processing.
images/download/attachments/92979989/image2022-3-29_13-39-10.png
X and Y define the offset added to single RGB channels. The higher these values are, the more distorted the lens. Typical values are around 1-2, anything else looks unrealistic.
