This chapter describes container plug-ins. The container plug-ins are found in the following plug-in folders:
Maps: Contains standard plug-ins.
Maps-Adv: Contains advanced plug-ins.
Maps-Lab: Contains experimental plug-ins. Since these plug-ins are experimental and not supported, they are not documented here.
Maps-Man: Contains a set of Manager plug-ins used for batch creation of 3D Objects such as regions, borders, and so on.
Maps-Obs: Contains obsolete plug-ins, installed only for backward compatibility. These plug-ins should not be used when designing new scenes. Since these plug-ins are obsolete and not supported, they are not documented here.
Tools: Contains tool plug-ins.
See the following sections for more information:
- 3D Border Manager
- 3D Line Manager
- 3D Line Tracer
- 3D Map Telestrator
- 3D Map Telestrator Design
- 3D Region Manager
- 3D Roads Manager
- Center Map
- CWM Client
- Focus On Map
- Geo Text
- GeoData Reader
- Hop It
- Hop Sync
- Hops Manager
- KML Reader
- Label AddOn
- Label and Go Assistant
- Label It
- LatLongGrid
- Locator Control
- Map Layers
- Map Layers Control
- Map Tiler
- Map Zoom
- Mouse2Memory
- Mute
- NavCom
- NavFade
- NavFinder
- Navigator
- NavScale
- NavSlave
- Place Finder
- Publish To Design
- Region2Tex
- Trace It
- World Position
