The Publish To Design plug-in enables updated parameters to be set directly to the design they came from (either container hierarchy or object pool) by pressing Publish To Design or create a new design out of modified data by assigning a new name under the New Design tab.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps_Adv
Publish To Design Properties
  • Publishing Target: Publishes using the original design or creates a new design.
  • Design Name: Sets the new name for the new design or selects a design from the Designs list.
  • Publish to Design: Sends the label back to where it came from, but it does not refresh the scene.
  • Publish and Refresh: Sends the label back to where it came from and refreshes the scene.
