The Hop It plug-in is a utility plug-in which connects the specific design with a hop.
It is used when the designs (for example, labels, regions etc.) were not generated from the hop you want to connect them to (or from no hop at all).
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps_Adv
Hop It Properties
Hop Mode
Automatic: Sets hop points automatically (based on searching all hops locations and connecting to the one which is closest).
Manual: Sets hop points using the Hop Point parameter.
Hop Point: Sets the hop point in the hop sequence. Note that the animation is built in the same sequential order as the list of Hop Points (Map-Start, Destination-1, Destination-2, and so on). If two hops use the same Hop Point, the animation does not work properly.
The three plug-ins that are influenced are Hop Sync, 2D Label and Label It.
