The Label AddOn plug-in assigns images, geometries and text based on label parameters.
Labels can have up to four extra parameters.
  • Label parents: Country, Admin1, Admin2 (also see Place Finder )
  • Label type: Type
Based on the container name (case sensitive), CWMClient updates the Value field in the plug-in with the correct value. For example, if you have selected London and you have a Label AddOn plug-in on a container named Country it receives the value of United Kingdom and if you have another Label AddOn plug-in on a container named Type It receives the value of Capital. A use case for this plug-in is whenever you want to have flags for all countries in the world in a folder and use the right flag based on the country. Another use case is having different images for different types and using the correct image based on the type.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Maps_Adv
Label AddOn Properties
  • Type
    • Images: Can be applied from the database on a local container.
    • Geometries: Can be applied from the database on a local container.
    • Text: Can be changed on the local container.
  • Value: Provides values used to seraph the object or set the text. Can be edited for testing.
  • Prefix: Sets the prefix used for searching the database. For example MyImages/Flags/Suffix or _small.
  • Hide if Empty: Hides the container if an object/image is not found.
  • Update: Tests the prefix and suffix.
