Viz Plug-ins User Guide
Text FX Plus Plus
images/download/thumbnails/125442203/ico_tfx_pp.png
The Text FX Plus Plus plug-in works in combination with the Pathfinder plug-in and allows to arrange a text among a defined spline.
Supported Pipelines
Classic Render Pipeline
images/s/-29r3su/8804/xgjkrn/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
Text FX Plus Plus Properties
  • Position Wrap
    • Interpolate: Above 100% or below 0% of Path Position continues the direction of the spline.
    • Clamp: Stops the string on the spline endpoints.
    • Repeat: Causes the string to move to the other spline endpoint as soon as it moves over the endpoint.
    • TextFx: Positions characters by the relative spline of each character using the common TextFx parameters.
  • Scheme Type: Defines how the text looks at 0% and 100% progress.
    • In -> In: at 0% first character is at the beginning of the spline, at 100% last character is at the end of the spline.
    • In -> Out: at 0% first character is at the beginning of the spline, at 100% first character is at the end of the spline.
    • Out -> In: at 0% last character is at the beginning of the spline, at 100% first character is at the end of the spline.
    • Out -> Out: at 0% last character is at the beginning of the spline, at 100% last character is at the end of the spline.
  • Progress (%): Animates the progress of the effect(s).
  • Position: Positions the characters using the spline as a position axis.
  • Rotation: Rotates the characters using the spline as a rotation axis.
  • Scale: Scales the character’s X, Y and Z-axis using the spline as a scaling graph.
  • Color: Applies Color Change on character.
  • Alpha: Applies Alpha on the characters using the spline as a alpha graph.
  • General: Enables rotation, offset and align properties.
    • Rotate X/Y/Z: Adds extra Rotation to each character.
    • Text Offset: Sets the text offset.
    • Align: Rotates the characters to follow the spline movements.
  • TextFX: See Common Text FX Properties.
    • Direction: Sets the direction of the text effect sequence. Normal starts with the first character (e.g. left). Opposite starts with the last character (e.g. right). Random uses a random order (see Random Seed). Static means that all characters are processed at the same time. Wave starts with the first character, animates the effect from 0 to 100% and then down again to 0%. Center starts the effect from the center of the text. 2 Center starts the effect at the same time from the beginning and the end of the text. They meet at the center.
  • Rotation: Defines the rotation effect to apply on the characters for each axis.
  • Scale: Defines the scale graph to apply on the characters for each axis.
  • Color: Defines the color gradient effect to apply on the characters.
  • Alpha: Defines the alpha effect to apply on the characters.
