Viz Plug-ins User Guide
Control NDI
images/download/thumbnails/114312341/image2021-3-16_10-29-49.png
The Control NDI plug-in allows to select and activate a certain NDI source available in your network from within Viz Artist or from a control application like Viz Trio.
images/download/attachments/114312341/image2021-5-5_9-43-50.png
Control NDI exposes the NDI source selector to external applications like Viz Trio or Viz Pilot. An operator can set a new NDI available within the network which is then taken by the plug-in and set for the live input source. It also offers basic testing possibilities for the designer by providing a list of discovered sources. To switch to a new NDI source, copy the source from the NDI sources list and paste it into the Set Source field.
Please use the Refresh Button, if NDI sources do not show up immediately.
To Use with Viz Trio
images/download/attachments/114312341/image2021-5-5_10-2-47.png
You need to manually enter a NDI source into the control field.
Information: Due some limitations on the Viz Trio side, it is currently not possible to do a discovery of sources and to provide a dropdown list.
