Viz Plug-ins User Guide
Control Num
images/download/thumbnails/114312344/ico_controlnum.png
The Control Number plug-in (also known as Control Num) is used to be able to decide how a number input is to be formatted. It can be a value given by the control client user or by any external source. It should be used instead of Control Text when numbers are to be the input value. To make it work, add the plug-in to the container that holds the text object.
Control Num Properties
  • Minimum Input: Sets the minimum allowed input value.
  • Maximum Input: Sets the maximum allowed input value.
  • Input Value: Shows the current input value. Enter a value to test the number formatting.
  • Show Verbatim: Disables all formatting when enabled.
  • Thousand Separator: Sets the required thousand separator for the output.
  • Plus Prefix: Applies the prefix entered here in front of positive values.
  • Minus Prefix: Applies the prefix entered here in front of negative values.
  • Suffix: Applies the string entered here after all values.
  • Decimal Point: Defines the decimal point for the output.
  • Decimal Places: Sets the number of decimals that are shown by the output.
  • Leading Zero: Places a zero in front of decimal values between 1 and -1 when enabled.
  • Zero Replacement: Sets the string to show instead of zero values.
