Viz Plug-ins User Guide
Align Text by Character
The Align Text by Character plug-in aligns the text content by centering the text in each line to the specified token. If the token is found multiple times on the same line, only the first one is used.
Properties
Token: The character to be used as the token to center the text.
Example
Text aligned on the colon (:) character:
Note: This plug-in only works with the Text plug-in in the Viz Engine Render Pipeline.
