Viz Plug-ins User Guide
Pie Slice
images/download/thumbnails/114307171/image2022-11-29_13-53-27.png
The Pie Slice plug-in is used with the Pie Values plug-in to create and animate a pie chart of up to 20 slices.
Note: This plug-in is located in: Plugins -> Container plug-ins -> Presenter
Pie Slice Properties
  • Obj Min / Max: Maps the input values to the values on the cylinder object. Adjust these together with Bar Max/Min on the Pie Values plug-in to get the required effect between input values and visual effect.
  • Offset: Offsets the slice from the center of the pie chart.
  • Text Offset: Offsets the text label from the center of the pie chart.
  • Control Text Values: Sets the type of text. Available options are No, Integer, Float and Formatted.
  • Initialize: Initializes the value of the pie slice.
