Viz Plug-ins User Guide
Version 5.2 | Published December 12, 2023 ©
Text FX Slide
images/download/thumbnails/95402182/ico_tfx_slide.png
The Text FX Slide plug-in allows you to create a sliding animation of the characters on the X, Y and Z-axis.
Supported Pipelines
Classic Render Pipeline
images/s/2wwyjx/8804/1yuue1v/_/images/icons/emoticons/check.svg
Viz Engine Render Pipeline
images/s/2wwyjx/8804/1yuue1v/_/images/icons/emoticons/error.svg
Text FX Slide Properties
  • X, Y and Z Distance: Defines direction and distance of moved text.
  • Show Direction: Enables and disables view of movement vector.
