Viz Plug-ins User Guide
Version 5.2 | Published December 12, 2023 ©
CFX Jitter Position
images/download/thumbnails/114312220/ico_cfxjp.png
The CFX Jitter Position plug-in creates a jittering motion of the containers by randomly changing the position of each container. The degree of position change and the starting sequence of the jittering can be altered. To create an animation, animate the progress. Other values can of course be animated as well.
Note: This plug-in is located in: Plugins -> Container plug-ins -> ContainerFx
CFX Jitter Position Properties
  • Use Axis: Defines on which axis or axes the containers moves to create the jittering effect.
  • Lock Axis: Gives the same values for Range and Randomness for all axes when enabled. If you disable it, Range and Randomness for each of the axes is shown and can be set individually.
  • Range: Sets the range of the jittering movement.
  • Randomness: Sets the intensity of the jittering movement.
