Software Requirements
This section describes the software requirements for the Viz Pilot system.
Note: This is an overview, so always check release notes for exact requirements.
Components
System Requirements
Minimum client system requirements
Windows 7
1 GHz 32-bit (x86) or 64-bit (x64) processor
1 GB RAM (32-bit) or 2 GB RAM (64-bit)
40 GB hard drive with at least 15 GB of available space
Supported client operating systems
Windows 10 Enterprise
Windows 10 Pro
Windows 8 Enterprise 64-bit
Windows 8 Pro 64-bit
Windows 7 Professional 64-bit (recommended)
Windows 7 Enterprise 64-bit
Windows 7 Ultimate 64-bit
Supported server operating systems
Windows Server 2012 R2 Update
Windows Server 2012
A specific version and service pack of an operating system will not be supported after the official Microsoft support end date. This is the latest date of support from Vizrt. Earlier support end dates will be announced in release notes for new versions of Viz Pilot.
Minimum supported versions of software components Viz Pilot depends on
Database, one of:
Graphic Hub 3.0 (with Graphic Hub REST 2.0) or newer, or
Oracle 11 or 12.2
Media Sequencer 4.0
Viz Engine 3.3
Recommended server system requirements
This depends on the overall system configuration and should be worked out together with your local support.
Viz Pilot Database Requirements - Oracle
In this case, the Viz Pilot database is an Oracle database server. Usually, two database servers are installed where one is used for manual failover. Viz Engine graphics data is stored on the Graphic Hub.
Viz Pilot Database Administrator Requirements
The Pilot Database Administrator tool (Pilot DBA) is a small application used for installing, upgrading, exporting, importing, and setting various parameters for the Viz Pilot Database. It is purely a DBA tool, and should therefore only be used by database administrators.
Viz Pilot Database Requirements - Graphic Hub
In this case, the Viz Pilot database is a Graphic Hub, accessed via a Graphic Hub REST server. For full installation and migration information, see the Graphic Hub User Guide.
Migration from Oracle to Graphic Hub
To move data from Oracle to Graphic Hub, the schema in the Oracle database must be Viz Pilot 6.x or later. To upgrade the schema use the Pilot DBA (see Database Administration). Once the schema is 6.x or later, import the data into Graphic Hub.
Once the data has been imported to Graphic Hub, the schema version will follow the Graphic Hub version. Any required schema updates will happen the first time the Graphic Hub is started after a version upgrade for the selected data directory.
The Pilot Database Administrator tool (Pilot DBA) is no longer required once you have migrated to Graphic Hub.
New Installations
For fresh installations, install Graphic Hub as described in the Graphic Hub User Guide.
Director Requirements
The table below lists the machine specifications for a typical newsroom system setup, where Director is the control application receiving the playlist.
Component |
Requirement |
Software |
Viz Pilot Media Sequencer Optional: Viz World Client (32-bit), TimeCode Monitor, Viz PreCut. Optional: If you are using a local Viz Engine to preview video clips from Viz One, Viz Engine must be installed with video codecs (e.g. MPEG-4 codec and Haali Media Splitter). Optional: Windows Media Player 11 for video clip preview in Object Store. Note: Local preview plugin supports 32 and 64bit versions of Viz Engine. If both 32 and 64 bit versions are installed, the 64 bit will be used regardless of which version is the newest. |
Local drive access |
Access to Oracle client files and folders, is using Oracle database. |
Network access |
Mapped drive to Object Store still store folder |
Director gets its Viz One connection parameters from the Viz Pilot database.
Vizrt recommends the use of remote preview that has no need for a local Viz Engine or graphics cards on the client machine.
Viz Pilot News Requirements
The table below describes a basic setup of Viz Pilot News for journalists and editors.
Component |
Requirement |
Software |
Viz Pilot Optional: Object StoreViz World Client (32-bit) 12.0 or later Newsroom system client Optional: If you are using a local Viz Engine to preview video clips from Viz One, Viz Engine must be installed with video codecs (e.g. MPEG-4 codec and Haali Media Splitter) Optional: Viz EasyCut or Viz PreCut for video clip editing. Note: Local preview plugin supports 32 and 64bit versions of Viz Engine. If both 32 and 64 bit versions are installed, the 64 bit will be used regardless of which version is the newest. |
Read access to Oracle client files and folders, if using Oracle. |
Network access |
Mapped drive to Object Store still store folder. |
Vizrt recommends the use of remote preview that has no need for a local Viz Engine on the client machine; hence, local preview is not recommended.
Viz Pilot News gets its Viz One connection parameters from the Viz Pilot database.
Note: In Viz Pilot News, the timeline editor does not work on virtual machines.
Template Wizard Requirements
Template Wizard is an easy-to-use software wizard, visual template editor, design and scripting tool. It is used to create, manage and categorize templates for graphics, with images, maps and video. Template Wizard can also be used to create control templates for Viz Trio and Viz Ticker3D.
Template Wizard can be installed as a stand-alone product for editing and running Viz Pilot templates without a Viz Pilot Database server, for example for use with Viz Trio or Viz Ticker3D. In this case no Oracle Client is required, and the use_database setting in the ContentPilot.ini file (under the [TEMPLATE_WIZARD] section) must be set to ‘n’.
It is possible to install Template Wizard on the same machine as Viz Artist; however, it is recommended to install it on a separate design client for template designers.
Template Wizard specifications
Component |
Requirement |
Software |
Media Sequencer Optional: Windows Media Player 11 for video clip preview in Object Store Optional: Viz World Client (32-bit) |
Template Wizard connects to the Media Sequencer for testing and previewing of template graphics. The Media Sequencer connection defaults to localhost. To use a different host set the command line option -mse <host> in Template Wizard’s target path.
Pilot Data Server Requirements
Pilot Data Server
The Pilot Data Server is installed as an application layer on top of the Viz Pilot database. It acts as an application server for accessing the Viz Pilot database and other services. The Pilot Data Server may be asked to handle requests from scripts to provide information on data elements, or to provide Preview Servers the information needed to resolve which scene and data is to be rendered by the Preview Server.
The Script Runner Service comes packaged with the Pilot Data Server. Thumbnail Generator is an optional component, which can be selected during the Pilot Data Server installation.
The Script Runner Service provides users with a simple way to use the Update Service without needing to create their own service. See Update Script Editor.
Thumbnail Generator
The Thumbnail Generator is a Windows service. As data elements are created or changed, it automatically generates thumbnails of them. The thumbnails are stored in the Viz Pilot database.
Thumbnail Generator requires a Preview Server, which is used to serve the thumbnails in the data element feed.
Pilot Data Server specifications
Component |
Requirement |
Software |
Pilot Data Server |
Service(s) |
Vizrt Pilot Data Server Vizrt Script Runner Vizrt Thumbnail Generator |
Operating system |
Refer to the Viz Pilot Release Notes |
Crop Service Requirements
Crop Service
The Crop Service is a tool that allows for basic cutting and zooming of images, and allows users to quickly add new images to a data element.
Crop Service specifications
Component |
Requirement |
Software |
Crop Service |
Service(s) |
Vizrt Crop Service |
Operating system |
Viz Engine Preview Server Requirements
The Preview Server is used in situations where one or more Viz Engines provide frames for snapshot or thumbnail generation. It is used by the Viz Trio client or Viz Pilot to fetch previews of overlay graphics, for example for the Timeline Editor or the Thumbnail Generator.
The Preview Server can run on the same machine as a Viz Engine, but it is also possible to specify additional Viz Engines in order to spread the load.
Preview Server can manage a pool of Viz Engines. Clients can query it for a Viz Engine that matches a specific video mode. It provides load balancing, video mode matching and can be used to create a redundant renderer pool. The pool of Viz Engines is configured on the Preview Server Web Interface.
For full information on requirements, see the Preview Server Administrator Guide.
