Display Font
The template and data list font settings for Director is set in the initialization (INI) file ContentPilot.ini, but in registry for Viz Pilot News.
*font: *Sets the font for Director. This parameter by default set to MS Sans Serif, but can be changed.
*ListDisplayFont: *Sets the font for Viz Pilot News. This string value is not set by default, and can therefore be used to override the operating system defaults.
To set the display font for Director
Open the ContentPilot.ini file
Select the LANGUAGE section and set a new Unicode *font *parameter.
Save the file, and restart Director for the changes to take effect.
To set the display font for Viz Pilot News
Open Registry
Search for the key:
Windows 32-bit: HKEY_LOCAL_MACHINE\SOFTWARE\\[vizrt]\ActiveX\TemplateFiller
Windows 64-bit: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ [vizrt]\ActiveX\TemplateFiller
Add the string value ListDisplayFont with the desired font name as parameter.
