Viz Pilot Edge User Guide
Version 2.4 | Published March 31, 2023 ©
Editing Images
Images can be added to a template or data element that contain an image field, which can be set in Template Builder. The image can be cropped using the Image Editor. If image constraints (Minimum Size of the Image and Aspect Ratio) are added to the image field in Template Builder, a frame is shown in the Image Editor that reflects those constraints.
Using the Image Editor
This section shows how to use the Image Editor both with and without image constraints enabled.
Selecting an Image
  • If no image is selected, click the image placeholder in the Fill In Form or find the desired image in the Find Media tab:
images/download/attachments/85888712/image2019-5-16_11-44-31.png
  • Open an image by double-clicking it.
images/download/attachments/85888712/image2018-8-15_14-20-47.png
Editing with Image Constraints
If image constraints are enabled for the image field, the Image Editor will open in a new window.
  • Adjust the frame that has a size based on the image constraints to the desired position.
  • Click Ok to place the cropped image in the Fill In Form.
images/download/attachments/85888712/image2018-8-23_12-11-16.png
Editing without Image Constraints
To crop an image without image constraints, click Edit and crop the desired area with your cursor:
images/download/attachments/85888712/image2019-5-16_11-45-39.png
Tip: Open an image from the Find Media tab directly in Image Editor by dragging it into the image placeholder and pressing ALT.
