Viz Pilot Edge User Guide
Version 2.4 | Published March 31, 2023 ©
Control Plugins Overview
Supported Control Plugins
Plugin Name |
Comments |
Control Action |
Control Action table |
Control Bars |
Control Chart |
Control chart works with VDT plugins. You can add and delete rows when filling in numbers. |
Control Clip |
Control Condition |
Control Container |
Control DB Object |
Control Data Action |
Control Datapool |
Control Feed |
Control feeds, like Nasdaq, for example. |
Control Field Identifier |
Probably works, need to check full workflow for this. |
Control Text |
The text plugin from the new Viz Engine renderer pipeline. |
Control Geom |
Remember to set up search provider towards GH for using this. Deny upward browsing seems to be broken for geoms. |
Control Hide in range |
Control Hide on Empty |
Often used to hide a group when a text field or other is left empty. |
Control Image |
Control Keyframe |
Control List |
Works as a regular table but is missing the functionality of moving lines up and down. |
Control Material |
Control NDI |
Control Number |
Control Object |
Control object is normally added automatically to a scene when you add another control plugin. It is in this plugin you mark if a scene is part of a transition logic set or not. There should normally only be one control object in the scene. The exception is when you use control list when there is a control object for every line. The functionally of writing controlfields directly in the control object is currently not supported. |
Control OMO |
This controls an Integer from 0 to 5 etc. It is typically nice to use a dropdown for these with proper field names. |
Control Parameter |
Control Payload |
Control Pie |
Control Sign Container |
Control Soft clip |
Control Stoppoint |
Control Classic Text |
In general control text is supported. But the full workflow for rich text may not be supported. |
Control VBI |
Control Video |
Control Field Renamer |
Control Plugins Not Supported
Plugin Name |
Comments |
Control Apply SHM |
Type Custom, uncertain if this is working and how it is supposed to work. |
Audio |
This is not a supported field type. |
Control Clock |
Not supported in Template Builder. |
Control Maps |
Currently not working. Requires Viz Engine 4.3 and more. |
Control Multihop |
Depends on maps to work. |
Control Placeholder |
This plugin is only valid for Viz Trio and was used to mark a container where you could place predefined design elements for Viz Trio designer. |
Control WoC |
A replacement of the Control Maps plugin with much more options and on-the-fly feedback from Viz Artist/Engine. |
