Gateway Administrator Guide
Version 5.6 | Published May 15, 2024 ©
Viz Multiplay Gateway Configuration
Viz Multiplay can be used as a MOS client. This means that the rundown is created in a Newsroom Computer System (NCS). The rundown can be transferred to the local Media Sequencer from NCS via Gateway and controlled by Viz Multiplay.
Setting up Gateway to Act as a MOS Client
The Media Sequencer must first be configured to connect to a Gateway, which connects to multiple NCSs. All the rundowns controlled by the Gateway will then be listed when you add an external playlist to a show in Viz Multiplay.
Open Settings > MOS Config:
MOS Client Status
In this scenario, the MOS client is the Media Sequencer. The MOS client must be configured to communicate via the MOS protocol to a Gateway.
MOS Client Status shows whether the Media Sequencer is able to connect to the Gateway.
You can also Start and Stop the local client.
MOS Client Settings
Gateway Host: Host name or IP of the machine running Gateway.
Send available status back to NCS: Sends the available status for elements containing clips and/or images back to the NCS as Ready or Not Ready.
Send local channel assignments back to NCS: It is possible to make last-minute changes to an element's playout channel in Viz Multiplay. The Media Sequencer then sends this channel assignment back to the newsroom system if this setting is enabled. If this setting is disabled, the local change may be overwritten on the next update from the newsroom system.
Send video status changed back to NCS: Sends the clip playback status (CUED, PLAYING, STOPPED) back to the NCS.
Auto-activate MOS playlists in profile: If no client application operates the MOS rundown (and if it's controlled by an automation system, for example) you can auto-activate all MOS playlist for a specific profile.
Apply Settings: Applies the changed settings without closing the window. This button is only enabled when changes have been made.
