Gateway Administrator Guide
Version 5.6 | Published May 15, 2024 ©
MOS Protocol Support
MOS Profile Support
Gateway supports the following MOS profiles:
Profile |
Definition |
Supported |
Vizrt Comment |
0 |
Basic Communications |
yes |
1 |
Basic Object Based Workflow |
yes |
2 |
Basic Running Order/Content List Workflow |
yes |
3 |
Advanced Object Based Workflow |
partly |
Only mosItemReplace is used. |
4 |
Advanced RO/Content List Workflow |
yes |
5 |
Item Control |
partly |
Only roCtrl is supported. |
6 |
MOS Redirection |
yes |
7 |
MOS RO/Content List Modification |
no |
Gateway supports these MOS protocol versions:
Protocol version |
Supported |
2.6 |
yes |
2.8.0 |
yes |
2.8.1 |
yes* |
2.8.2 |
yes* |
2.8.3 |
yes* |
2.8.4 |
yes* |
2.8.5 |
yes* |
4.0.0 |
yes** |
*Both the Media Sequencer hosting the central Gateway and Media Sequencer clients must be upgraded to version 5.3 or later to support MOS Protocol version 2.8.1 or later. **The Media Sequencer hosting the central Gateway must be upgraded to 5.6 to support MOS Protocol version 4.0.0. The Media Sequencer clients must be upgraded to at least 5.3, but in order to support secure websocket communication with the central Gateway, the clients must be upgraded to 5.6 as well. |
For more information about the MOS protocol, see mosprotocol.com.
