Gateway Administrator Guide
Version 5.6 | Published May 15, 2024 ©
Active Running Orders
The Active Running Orders tab contains a table of Running Orders (RO) for each NCS server, with the following columns:
Slug: Descriptive name of the RO.
Timestamp: Time when the RO was last modified. The RO will be cleared if it has not been updated for a number of days, as configured with the RO days to live setting under General Configuration.
Remote Endpoint: If specified, the RO is routed to the control station with this remote endpoint.
Either an ID identifying the control station (for websocket connection), or the IP address of the control station (for TCP connection).
The list of running orders can be expanded and collapsed per NCS server, by clicking the arrow icon left of the NCS ID. Note that the list of active RO's will only contain RO's that the NCS servers have sent to the Gateway. There may exist RO's on an NCS that has not been sent to the Gateway, for example if an RO is not active, or an RO for a different MOS ID.
