Viz Ticker comes with several installers to setup the system.
- Important Before Installation
- Requirements
- Program Starting Sequence
- Installing Viz Ticker Wizard
- Installing Viz Ticker Client
- Installing Viz Ticker Web Client
- Installing Viz Ticker Service
- Installing Viz Ticker Feed
- Installing Viz Ticker System Tool
- Upgrading the Existing Viz Ticker Configuration
- Installation Directories
- System Log Files
Depending on your setup, you may also need to install the following:
Viz Ticker Service: Required for scrolling Viz Ticker Systems.
Viz Ticker Feed: Used for populating carousels with data from an external source.
