Installing Viz Ticker Feed
Note: If Viz Ticker Feed is already installed on the machine, you must first remove the old program version before installing the new one, see To uninstall Viz Ticker Feed, see below.
  1. Run VizTickerFeed-<Product Version>.msi.
  2. Follow the on-screen installation procedure.
Uninstalling Viz Ticker Feed
  1. Select Start > Control Panel > Programs > Uninstall a program and choose the component to uninstall.
Note: The software settings are not deleted when uninstalling Viz Ticker Feed.
