Viz Ticker Service is a component responsible for controlling the sequence of ticker messages in Viz Ticker to the Viz Engine. This component is necessary to run a scrolling carousel in Viz Ticker.
IMPORTANT! Viz Ticker must be installed and run on the Viz Engine used for output for scrolling carousels.
Installing Viz Ticker Service
Note: If Viz Ticker Service is already installed on the machine, you must remove the old program version before installing the new one.
  • Run the VizTickerService-<Product Version>.msi installer.
  • Follow the on-screen installation procedure.
Uninstalling Viz Ticker Service
  1. Select Start > Control Panel > Programs > Uninstall a program, and choose the component to uninstall.
Viz Ticker Service Options
Viz Ticker Service is installed and run as a service, and the configuration is stored in the TickerService.config file located in the %ProgramData%/Vizrt/Viz Ticker/Ticker Service folder. For any changes to take effect, the Viz Ticker Service has to be restarted, for example using Windows Services. The following options can be configured:
Options
Behavior
<logging mode="Basic" />
Defines the log level to use, can be Off, Basic or Full, default is Basic.
<port value="6301" />
Defines the port to bind the socket interface to, default is 6301.
