Installing Viz Ticker Wizard
Note: If Viz Ticker Wizard is already installed on the machine, remove the old version before installing the new version.
Run VizTickerWizard-<Product Version>.msi.
Follow the on-screen installation procedure.
Uninstalling Viz Ticker Wizard
Select Start > Control Panel > Programs > Uninstall a program, and choose the component to uninstall.
Note: The software settings are not deleted when uninstalling Viz Ticker Wizard.
Viz Ticker Wizard Startup Parameters
After installing Viz Ticker Wizard, the Media Sequencer startup parameter can be modified in the Viz Ticker Wizard Properties.
Note: If Viz Ticker Wizard should connect to a Media Sequencer on a specific machine not on the localhost, create a shortcut and type the machine name as the first parameter after the program path.
