Installing Viz Ticker System Tool
Note: If Viz Ticker System Tool is already installed on the machine, you must remove the old program version before installing the new one, see Uninstalling Viz Ticker System Tool.
Run VizTickerSystemTool-<Product Version>.msi.
Follow the on-screen installation procedure.
For more information on the location of the program files, see Installation Directories
Select Start > Control Panel > Programs > Uninstall a program and choose the component to uninstall.
