Viz Pilot Edge User Guide
Version 2.2 | Published December 21, 2021 ©
Requirements and Installation
This section shows you how to plan, install and configure a new Viz Pilot Edge system. It also explains how to prepare your existing Viz Pilot system to be able to work with Viz Pilot Edge.
System Requirements
Pre-Installation Requirements
  • A Vizrt Viz Pilot system must be installed and actively in use.
  • The following Viz Pilot backend infrastructure is required:
    • Oracle or Graphic Hub servers to store Pilot templates and data elements.
    • NRCS system integrated with Viz Pilot system.
    • Viz Preview Server or Connection Broker for graphics preview.
    • Set of Viz Artist scenes used in broadcast.
Hardware Requirements
There are no known hardware limitations for Viz Pilot Edge, other than requirements stipulated by newsroom systems that are hosting the client.
Software and Browser Requirements
Note: It is strongly recommended to use the latest version of Viz Pilot Edge.
If you are running Viz Pilot Edge inside a browser, the following minimum requirements apply:
  • Microsoft Internet Explorer 11 +
  • Chrome 64 +
  • Safari 11.0 +
Pilot Data Server Back-end Requirements - Oracle
You only need to consider the Pilot Schema version below when using Oracle.
Pilot Edge and Pilot back-end Compatibility Matrix
Pilot Edge version
Pilot Data Server version
Template Builder version
Preview Server version
Viz Engine version
2.0
8.6
2.0
4.4.1
8.4
4.2
1.6
8.5
1.3
4.4.0
8.4
3.14.2
Pilot Data Server Back-end Requirements - Graphic Hub
In most instances, only Pilot Schema version >= 6.0 can be used with a Graphic Hub back-end. So, if you running Pilot schema 5.x, then you need to upgrade it first to, at least, version 6.0. Full list of compatible versions is available in the Graphic Hub Administrator Guide.
Pilot Schema Version
Pilot Director
Pilot Edge Version
Graphic Hub Version
GH Rest Version
GH Manager Version
to import/clean schema
8.4
8.6
2.0
3.4.2
2.4.2
5.4.1
8.4
8.6
1.6
3.4.1
2.4.1
5.4.1
8.4
8.5
1.5
3.4.0
2.4.0
5.4.0 can import schema 6, 7, 8,
8.3.0 and 8.4.0
8.3
8.3
3.20. or 3.3.0
2.2.0 or 2.3.0
5.2.0 or 5.3.0 can import schema 6, 7, 8,
8.3.0
8.0
8.0
3.0.2 to 3.1.1
2.0.2 to 2.1.1
5.1.1 or 5.0.2 can import schema 6, 7, 8,
7.0
7.0., 7.1, 7.2
3.0.0 or 3.0.1
2.0.0 or 2.0.1
5.0.1 can import schema 6,7
Installation
If Pilot infrastructure has not been installed, please follow the Installation procedure is described in Pilot Data Server Installation and other related administration guides. Viz Pilot Edge opens as a web application in a browser:
Viz Pilot Edge URL: The URL to access Viz Pilot Edge is: http://hostname:8177/app/pilotedge/PilotEdge.html.
