Viz Pilot Edge User Guide
Version 2.2 | Published December 21, 2021 ©
Workflows
Search for templates and media using Find Graphics and Find Media.
images/download/attachments/85888607/image2017-4-26_13_21_37.png
Selecting Find Media opens a panel where you can search for available videos and images.
Selecting Find Graphics opens a panel where you can search for available templates and previously saved data elements and library elements.
Basic Workflow
The basic workflow from a template to a data element ready for play-out is as follows:
  • Search for and open templates, data elements or media assets.
  • Search for resources using a variety of filter criteria.
  • Fill graphic templates with content using an auto-generated Fill In Form.
  • Preview graphics in the Preview Window.
  • Save the filled in graphic templates as data elements; they can also be saved in the library. Elements are stored in the Pilot Data Server.
  • Drag elements to a newsroom rundown where they will be available to Director for monitoring and play-out.
Note: At startup, the graphics panel or the media search panel can be shown rather than the welcome page. Select Show this on startup at the bottom right corner of the desired panel:
images/download/thumbnails/85888607/image2017-12-28_12-20-17.png
The most recent setting is saved in the browser's local storage.
About
Click the Viz Pilot Edge logo images/download/attachments/85888607/image2017-4-28_13_4_22.png at the top left corner for information on the software version, and links to local documentation and third-party licenses.
Log Window
Use the shortcut ALT + 1 to display a log window that shows messages, warnings and errors.
