Viz Pilot Edge User Guide
Version 2.2 | Published December 21, 2021 ©
Control Plugins Overview
Supported Control Plugins
Plugin Name
Comments
Control Action
Control Action table
Control Bars
Control Chart
Control chart works with VDT plugins. You can add and delete rows when filling in numbers.
Control Clip
Control Condition
Control Container
Control DB Object
Control Data Action
Control Datapool
Control Feed
Control feeds, like Nasdaq, for example.
Control Field Identifier
Probably works, need to check full workflow for this.
Control Geom
Remember to set up search provider towards GH for using this. Deny upward browsing seems to be broken for geoms. images/jira.vizrt.com/secure/viewavatar.svg VPE-3640 - Deny upward browsing and set path Resolved
Control Hide in range
Control Hide on Empty
Often used to hide a group when a text field or other is left empty
Control Image
Control Keyframe
Control List
Works as a regular table but is missing the functionality of moving lines up and down.
Control Material
Control Number
Control Object
Control object is normally added automatically to a scene when you add another control plugin. It is in this plugin you mark if a scene is part of a transition logic set or not. There should normally only be one control object in the scene. The exception is when you use control list when there is a control object for every line. The functionally of writing controlfields directly in the control object is currently not supported.
Control OMO
This controls an Integer from 0 to 5 etc. It is typically nice to use a dropdown for these with proper field names.
Control Parameter
Control Payload
Control Pie
Control Sign Container
Control Soft clip
Control Stoppoint
Control Text
In general control text is supported. But the full workflow for rich text may not be supported.
Control VBI
Control Video
Control Field renamer
Control Plugins Not Supported
Plugin Name
Comments
Control Apply SHM
Type Custom, uncertain if this is working and how it is supposed to work.
Audio
Currently Audio is not a supported field type
Control Clock
Currently not supported in Template Builder
Control Maps
Currently not working, Need Viz Engine 4.3 and more
Control Multihop
Depends on maps to first work
Control Placeholder
This is a plugin only valid for Viz Trio and was used to mark container where you could place predefined design elements for Viz Trio designer.
Control WoC
maps related
