Viz Pilot Edge User Guide
Version 2.2 | Published December 21, 2021 ©
Configuring the iNews HTML5 Plugin
As part of the configuration for Pilot Edge, a few steps need to be followed to be able to use the HTML5 plugin feature in iNews.
Firstly you must go to Avid's MediaCentral Newsroom Management Setup and Configuration Guide and follow the steps under the HTML5 Plugins section.
Once the Avid setup is complete, open iNews and select the queue named as HTML Plugins.
A URL for Pilot Edge is provided, and as a requirement, the parameter progid needs to be added to the URL. The value of progid must match the value of mosItemBrowserProgID, mosItemEditorProgID and mosItemPlayerProgID.
For example:
mosItemBrowserProgID = pilotmos
mosItemEditorProgID = pilotmos
mosItemPlayerProgID = pilotmos
mosPlugInID = Pilot Edge
URL = http://hostname:8177/app/pilotedge?mosid=PILOT&progid=pilotmos
Note: This configuration is not mandatory to use Show Edge.
