Viz Pilot Edge User Guide
Version 2.2 | Published December 21, 2021 ©
Other Workflows
Graphics Plugin (NLE)
The Graphics Plugin also supports the fill in form technology. Viz Pilot Edge can be opened from the Graphics Plugin, and the same interface is available in your craft editing system. Viz Pilot Edge is only available for handling graphics in this workflow.
Viz Pilot News
ActiveX-based templates used in Viz Pilot News cannot be migrated to HTML-based templates used in Viz Pilot Edge, because the technologies are incompatible. However, a simplified editor for these templates is available in Pilot Edge. To use the customized version of the templates, you need to recreate templates one-by-one over a period of time. Vizrt has tools to assist you with this process, see Migrating from Pilot News.
Template Builder
Template Builder is a tool to create and customize templates for Pilot Edge. You can use TypeScript to customize the templates (see below), or use Custom HTML Panels to load advanced self-hosted JavaScript and HTML UI to the template.
See also
