Viz Pilot Edge User Guide
Version 1.3 | Published September 27, 2018 ©
Keyboard Shortcuts
Most of the keyboard shortcuts in Viz Pilot Edge are the ones used in the timeline editor. They allow the user to navigate and make edits within the video clip.
A dialog with keyboard shortcuts for the timeline editor is available by clicking the
button in the timeline editor.
The following keyboard shortcuts are available in Viz Pilot Edge:
Action |
Shortcut |
Button |
Keyboard shortcuts information |
Shift + K |
Play/pause |
Space or Ctrl + Space |
Loop video |
R |
Mute |
M |
Delete selected items |
Backspace or Delete |
Select previous item |
Select next item |
Move 1 frame back |
, (comma) |
Move 1 frame forward |
. (period) |
Mark In point |
I |
Mark Out point |
O |
Go to In point |
Shift + I |
Go to Out point |
Shift + O |
Clear In/Out points |
Shift + C |
Play backward - press multiple times to increase speed |
J |
Pause |
K |
Play forward - press multiple times to increase speed |
L |
Play backward at 0.5x speed |
Alt + J |
Play forward at 0.5x speed |
Alt + L |
Move selected item left by 1s |
Ctrl + ← |
Move selected item right by 1s |
Ctrl + → |
Move selected item left by 10s |
Ctrl + Shift + ← |
Move selected item right by 10s |
Ctrl + Shift + → |
Move 10 frames back |
Shift + J |
Move 10 frames forward |
Shift + L |
Grow selected item by 1s |
Ctrl + Alt + → |
Shrink selected item by 1s |
Ctrl + Alt + ← |
Grow selected item by 10s |
Ctrl + Alt + Shift + → |
Shrink selected item by 10s |
Ctrl + Alt + Shift + ← |
Zoom timeline |
Shift + scroll |
Open an image from Find Media directly in Image Editor |
drag (into image placeholder) + Alt |
Open the Log Window displaying Messages, Warnings and Errors |
Alt + 1 |
