Version 5.0 | Published June 21, 2022 ©
AV Automation Devices Router
Use Router: Check to enable router control and select protocol from the list.
Router type: EVERTZ QUARTZ, GVG G-SMS7000, SW-P-08 TCP/IP, SW-P-08 SERIAL, VENUS, VIKINX SERIAL or VIKINX TCP/IP.
Port: Serial port (GVG G-SMS7000, Venus, SW-P-08 serial, and Vikinx serial).
Bit rate: Selectable serial bit rate (GVG G-SMS7000).
Parity: Parity bit, default None (GVG G-SMS7000).
Main Host: Hostname or IP address of the main router ( EVERTZ QUARTZ, SW-P-08 TCP/IP and Vikinx TCP/IP).
Main Port: IP port of the main router ( EVERTZ QUARTZ, SW-P-08 TCP/IP and Vikinx TCP/IP).
Backup Host: Hostname or IP address of the backup router (SW-P-08 TCP/IP).
Backup Port: IP port of the backup router (SW-P-08 TCP/IP).
Additional parameters: For future use.
