Version 5.0 | Published November 09, 2022 ©
MOS Object with Clip Templates Merged in a Mosart Template
A single MOS object is created for all Mosart templates of type PACKAGE or VOICEOVER from the default template set. In this example:
<mosExternalMetadata> node contains the list of variants for the Mosart templates of type PACKAGE and VOICEOVER.
<objID> of the MOS object is set to 25, representing a Mosart item type CLIP.
<objGroup> is the default template set name.
<type> node has name and category set to “CLIP”, and templateset set to the name of the default template set.
The variant for each template is built using some prefixes:
1) for PACKAGE, the variant is set to MAZ-<template variant>
2) for VOICEOVER, the variant is set to OFFMAZ-<template variant>
Note: When GroupByType is false, no MOS object will be sent for templates of type PACKAGE and VOICEOVER.
mosObj
objID
>LOWERTHIRDS</
objID
objSlug
>LOWERTHIRDS</
objSlug
mosAbstract
objGroup
>TEMPLATES</
objGroup
objType
>STILL</
objType
objTB
>50</
objTB
objRev
>1</
objRev
objDur
>0</
objDur
<!-- The status of the MOS object can be NEW, UPDATED or DELETED -->
status
>NEW</
status
objAir
>NOT READY</
objAir
createdBy
created
changedBy
changed
description
mosExternalMetadata
mosScope
>PLAYLIST</
mosScope
mosSchema
http://www.mosartmedialab.no/schema/mositem.dtd
mosSchema
mosPayload
mosarttemplate
type
name
"LOWERTHIRDS"
category
"GRAPHICS"
variants
fieldtype
"LIST"
value
"AUTOOUT"
variant
name
"AUTOOUT"
fields
field
name
"graphics_description"
fieldtype
"TEXT"
field
name
"graphics_id"
fieldtype
"TEXT"
field
name
"tc_in"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"tc_out"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"channel"
value
"DSK"
fieldtype
"LIST"
keylist
"channels"
field
name
"take"
value
"AUTO"
fieldtype
"LIST"
keylist
"taketypes"
fields
variant
variant
name
"KEEPWHILEBACKGROUND"
fields
field
name
fieldtype
"TEXT"
field
name
"graphics_id"
fieldtype
"TEXT"
field
name
"tc_in"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"tc_out"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"channel"
value
"DSK"
fieldtype
"LIST"
keylist
"channels"
field
name
"take"
value
"AUTO"
fieldtype
"LIST"
keylist
"taketypes"
fields
variant
variant
name
"KEEPWHILESTORY"
fields
field
name
fieldtype
"TEXT"
field
name
"graphics_id"
fieldtype
"TEXT"
field
name
"tc_in"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"tc_out"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"channel"
value
"DSK"
fieldtype
"LIST"
keylist
"channels"
field
name
"take"
value
"AUTO"
fieldtype
"LIST"
keylist
"taketypes"
fields
variant
variant
name
"NONEAUTOOUT"
fields
field
name
fieldtype
"TEXT"
field
name
"graphics_id"
fieldtype
"TEXT"
field
name
"tc_in"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"tc_out"
fieldtype
"TIMECODE"
inputmask
"mm:ss"
default
"00:00"
field
name
"channel"
value
"DSK"
fieldtype
"LIST"
keylist
"channels"
field
name
"take"
value
"AUTO"
fieldtype
"LIST"
keylist
"taketypes"
fields
variant
variants
<!-- List of active channels (graphics destinations) as configured in OverlayGraphics Interface-->
keys
name
"channels"
k
>WALL_2</
k
k
>WALL</
k
k
>TABLE</
k
k
>DSK</
k
keys
keys
name
"taketypes"
k
>AUTO</
k
k
>MANUAL</
k
keys
type
mosarttemplate
mosPayload
mosExternalMetadata
mosObj
The list of channels contains the active destinations (destinations linked to a graphic engine) as configured in the Overlay Graphics interface.
For details of configuration, refer to section xxx.
