Version 5.0 | Published November 09, 2022 ©
Vision Mixer Configuration Files
The configuration files for the following vision mixers (switchers) are listed here for convenience. See the inline commenting for parameter explanation:
GvgVideoSwitcherConfig.xml
DeviceConfig
name
"GvgVideoSwitcherConfig"
Properties
item
name
"SendBreak"
value
"true"
item
name
"EnableHeartbeat"
value
"true"
Properties
DeviceConfig
SendBreak: All GVG 4000 protocol switchers requires a break before connecting (but there are switchers which do not need this).
EnableHeartbeat: When no commands are issued, a heartbeat is sent to the vision mixer with an interval equal to the configured heartbeat interval.
GrassValleyCPLVideoSwitcherConfig.xml
DeviceConfig
name
"GrassValleyVideSwithcerConfig"
Properties
<!-- Interval in seconds when to test for a valid connection when not connected -->
item
name
"ConnectionCheckIntervalInSecondsNotConnected"
value
"5"
<!-- Interval in seconds when to test for a valid connection when connected -->
item
name
"ConnectionCheckIntervalInSecondsConnected"
value
"10"
Properties
DeviceConfig
RossVideoSwitcherConfig.xml
Note: This config replaces CarboniteVideoSwitcherConfig.xml.
DeviceConfig
name
"CarboniteVideoSwitcherConfig"
Properties
<!-- The properties below is the virtual cross point mapping for internal Ross Carbonite sources. Alias can be anything. Value is the virtual assigned crosspoint to be set in AV Config XML. Name is the RossTalk command for the item.
item
alias
"MediaStore1"
value
"1001"
name
"MS:1"
item
alias
"MediaStore2"
value
"1002"
name
"MS:2"
item
alias
"MediaStore3"
value
"1003"
name
"MS:3"
item
alias
"MediaStore4"
value
"1004"
name
"MS:4"
item
alias
"Black"
value
"1008"
name
"BK"
item
alias
"MatteColor"
value
"1009"
name
"BG"
item
alias
"ME1"
value
"1011"
name
"ME:1"
item
alias
"ME2"
value
"1012"
name
"ME:2"
item
alias
"MiniME1"
value
"1021"
name
"MME:1"
item
alias
"MiniME2"
value
"1022"
name
"MME:2"
item
alias
"MiniME3"
value
"1023"
name
"MME:3"
item
alias
"MiniME4"
value
"1024"
name
"MME:4"
item
alias
"MuliScreen1"
value
"1031"
name
"MSC:1"
item
alias
"MuliScreen2"
value
"1032"
name
"MSC:2"
Properties
DeviceConfig
SonyVideoSwitcherConfig.xml
DeviceConfig
name
"SonySwitcherConfig"
Properties
<!-- Truns the heartbeat mechanism on/off. -->
<!-- item name="EnableHeartbeat" value="false" / -->
<!-- The number of milliseconds before a time-out occurs when a read operation does not finish.
If set less than zero the time-out will be infinite -->
<!-- item name="ReadTimeout" value="100" / -->
<!-- ComPort2 is used for the SonySerialTallyDriver in split mode, using the second serialport for the SCU connection -->
item
name
"ComPort2"
value
"COM23"
<!-- The properties below routes the different commands sets to either the standard or the extra COM port
None: always com port 1,
Partial: com port 1 if the crosspoint range or mix effect range is supported by com port 2, otherwise com port 2
Full: always com port 2
item
name
"AutoTransComPort2"
value
"None"
item
name
"SetCrossPointComPort2"
value
"Full"
item
name
value
"Full"
item
name
"SetAuxCrossPointComPort2"
value
"Full"
item
name
"SetKeyFillCrossPointComPort2"
value
"Full"
item
name
"SetKeyerComPort2"
value
"Full"
item
name
"SetDskComPort2"
value
"Partial"
item
name
"SetTransTypeComPort2"
value
"Full"
item
name
"RecallRegionComPort2"
value
"None"
Properties
DeviceConfig
VizEngineSwitcherConfig.xml
DeviceConfig
xmlns:xsi
"http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd
"http://www.w3.org/2001/XMLSchema"
Properties
item
name
"ControlScenePath"
value
"Vizrt/VizOpus/ControlScenes/switcher"
item
name
"ControlSceneLayer"
value
"Back"
item
name
"NumberOfKeyBuses"
value
"8"
/> <!-- Number of key buses in template editor (default value is 4, only other valid option is 8) -->
Properties
DeviceConfig
VizrtIpSystemsVideoSwitcherConfig.xml
DeviceConfig
name
"VizrtIpSystemsVideoSwitcherConfig"
Properties
<!-- The path where EMEMs are stored -->
item
name
"PathToEmem"
value
"D:\Sessions\SessionName\emem\"
<!-- Set this to true if the crosspoint names should be sent in the command to the driver instead of the physical inputs for the NDI Outputs. Default: true.-->
item
name
"UseOutputCrosspointNames"
value
"true"
Properties
DeviceConfig
