Text FX Jitter Alpha
images/download/attachments/41798402/ico_tfx_ja.png
The Text FX Jitter Alpha plug-in creates a jittering motion of the characters by randomly changing the alpha value of each character. The degree of change and the start sequence of the jittering can be altered. To use the plug-in, add it onto a container with a font. To create an animation, animate the progress. Other values can of course be animated as well.
Text FX Jitter Alpha Properties
images/download/attachments/41798402/pc_tfx_ja_e.png
  • Effect What: Defines where the effect should have an effect. Available options are background (BG), foreground (FG) or both.
  • Alpha Begin: Sets the alpha level of the character at 0% effect.
  • Alpha End: Sets the alpha level of the character at 100% effect.
  • Randomness: sets the intensity of the jittering alpha changes.
