Light Blur
Allows the user to configure and create a light blurred image.
IMPORTANT! The light blur functionality is now a built in feature of the Viz Artist/Engine core. For future use it is therefore recommended to use the Dynamic Texture Media Asset.
Note: This plug-in is located in: Built Ins -> Container plug-ins -> Texture
Light Blur Properties
Width and Height: Sets the width and height of the blurred light. Available options are 2 to 2048.
Format: Sets the image format. Options are:
RGB
RGBA
Alpha
Luminance
Luminance Alpha
Save: Saves the blur as an image.
X and Y (%): Sets the position of the blur on the X and Y axis (50% places the blur at the origin).
Spread (%): Sets the spread of the blur.
Start: Sets the start color of the blur.
End: Sets the end color of the blur.
