![](assets/images/logos/VizTickerLogo.png)
Viz Ticker User Guide
Version 4.1 | Published January 22, 2024 ©
System Log Files
Logfiles for Viz Ticker Client, Ticker Feed, Ticker Wizard and Ticker System Tool are stored at %AppData%\Vizrt in the directories Viz Ticker Client, Ticker Feed, Ticker Wizard and TickerSystemTool. Assuming your user running the programs is called VizUser, then you normally find config and logfiles in:
C:\Users\VizUser\AppData\Roaming\Vizrt
Logfiles for the service component Ticker Service are stored at %ProgramData%\Vizrt in the directory Ticker Service, normally this would be C:\ProgramData\vizrt\Ticker Service.
Note: %AppData% and %ProgramData% are Windows environment variables. Windows Explorer resolves them into a folder path depending on operation system, system drive, current user and so on. For example, on Windows 7, %ProgramData%\Vizrt resolves to C:\ProgramData\Vizrt if Windows is installed on the C: drive.
Ticker System Tool Log Files
