Viz Ticker User Guide
Version 4.1 | Published January 22, 2024 ©
Installing Ticker Wizard
Note: If Ticker Wizard is already installed on the machine, remove the old version before installing the new version. Also, the Ticker System Tool is installed together with Ticker Wizard, if this option is selected during installation.
Run TickerWizard-<Product Version>.msi.
Uninstalling Ticker Wizard
Select Start > Control Panel > Programs > Uninstall a program.
Note: The software settings are not deleted when Ticker Wizard is uninstalled.
Ticker Wizard Startup Parameters
After installing Ticker Wizard, the Media Sequencer startup parameter can be modified in the Ticker Wizard Properties.
To modify the parameter, make sure that the Shortcut tab is selected, and modify the Target text box.
If Ticker Wizard should connect to a Media Sequencer on a specific machine, type the machine name as the first parameter after the program path.
