Viz Ticker User Guide
Version 4.1 | Published January 22, 2024 ©
Quick Start Guide
This section lists the steps required to set up and use a basic Viz Ticker carousel. Each of the steps is described in more detail in the following sections of this User Guide.
Prepare All Systems
Start Viz Artist and set On Air.
Make sure that the Media Sequencer is running.
Start Ticker Wizard and delete any existing carousels or output channels. These must be deleted before setting up a new Ticker System, see Ticker Carousels Panel and Output Channels Panel.
Make sure that Ticker Service is running (only required for scrolling carousels).
Set Up a Carousel in Ticker Wizard
Connect Ticker Wizard to Viz Engine (Viz Engine Connection Frame).
Click Select Scene to select the carousel scene (Main Panel).
Click Create Scrolling/Flipping Carousel and select the carousel and templates you require (Wizards).
Use a Carousel in Viz Ticker Client
Start Viz Ticker Client.
Select the <CarouselName> tab (Carousel Specific Panel).
Create new messages by clicking New Message or New Template Element.
Edit the contents of each message in the Elements Editor.
Move the new messages to the Carousel List.
Activate the System
In Viz Ticker Client, select the CONTROL tab (Control Panel). This is only visible if the Viz Ticker Client Startup Parameters include -control on.
Set Ticker System Main to On.
Set Program Main to On.
Take the carousel on air by setting <CarouselName> Main to On. This button is available in the <CarouselName> tab and the CONTROL tab. Your ticker carousel should now be displayed in the rendering window.
