Using Crop Tool
images/download/attachments/28386220/userinterface_croptool.png
  • Images
  • Crop Tool Functions
  • To crop an image with Crop Tool
  • To use an image from the clipboard
Images
Depending on the design of the template, the Crop Tool can make use of images from Object Store, any local computer file location, or the Windows Clipboard.
Note: A cropped image can only be used once, that is, a user cannot re-crop or search for an already cropped image. To create a new cropped image, the user must find the original image and add it to the Windows Clipboard again.
A crop tool is also used in Object Store; however, when used within Viz Pilot News, images are not saved to the Object Store database. Hence, even if an image from Object Store is used, the original image in Object Store will not be affected.
Note: Crop Tool images differ from Object Store and Viz One images in that it is not possible to fully control what images are used, hence policies on using such things as copyrighted images must be clear.
Crop Tool Functions
The Crop Tool is divided in three areas; a menu bar, an edit area (left), and a preview area (right).
images/download/attachments/28386220/newsroom_vos_editimage_menubtnscrop.png
The menu bar contains the following functions:
  • Save: Saves the image to the image directory set in the crop tool save path.
  • Cancel: Resets editing and closes the Crop Tool window.
  • Left 90: Rotates the image 90 degrees to the left.
  • Right 90: Rotates the image 90 degrees to the right.
  • Zoom: Zoom the editable version of the image to a size of; 500%, 200%, 150%, 100%, 75%, 50%, 25% and 10% of the original image size. In addition there is an option to Fit the image to the available space. Zoom can also be performed by using the mouse wheel. Zoom does not resize the saved image.
  1. Open a template or a data element.
  2. Click the image placeholder.
  3. Search for a stored image.
  4. Drag the image to the placeholder.
  5. Adjust the anchored frame and/or rotation of the image, and click the Save (CTRL+S) button on the tool bar.
images/download/attachments/28386220/userinterface_image_icon_ispaste.png
Note: This procedure requires that the template’s image component use the ImageSources.isPaste parameter.
  2. Search for and copy an image (e.g. web-based systems or file shares).
  3. Right-click the image icon and select Paste.
  4. Adjust the anchored frame and/or rotation of the image, and click the Save (CTRL+S) button on the tool bar.
Images Edited with Crop Tool
All edited images are saved as Portable Network Graphics (PNG), which is a bit-mapped image format that employs lossless data compression.
An edited image is saved with the same image and person information as the original image. The new file is given a default prefix “Crop”. The image Description field is also updated by adding the following text: “_Crop of: Description” where the phrase Description represents the image description from the original image. Images with key is also preserved.
Scene and Template Design
Calling Crop Tool from a Template
A scene can be designed to use an image of a specific aspect ratio. This is done in Template Wizard, by using the Image Component and its parameters DestWidth and DestHeight to set the width and height.
If an image is selected which does not match the parameters, the Crop Tool will be automatically opened, forcing the user to edit the image according to the pre-configured parameters.
Crop and Scale Image
If the crop uses the DestWidth/Height ratio, the cropped image will be rescaled to fit the DestWidth/Height values.
images/download/attachments/28386220/objectstore_crop_tool.png
Example - Setting Image Size
For example, if the template designer has set the DestWidth and DestHeight to 200 x 100 pixels (aspect 2:1) to set the aspect ratio and image size, and we have an original image of 2000 x 1500 pixels (4:3), then:
  • If the template user selects an area of 1250 x 625 pixels (2:1), the image will be cropped and scaled down to 200 x 100 pixels.
  • If the template user selects an area of 200 x 100 pixels (2:1), the image will be cropped to 200 x 100 pixels.
  • If the template user selects an area of 100 x 50 pixels (2:1), the image will be cropped and scaled up to 200 x 100 pixels.
    Note: In this case a warning is issued, but the image can still be used. The image will be scaled up and may look pixelated on air.
Example - Setting Aspect Ratio
If the DestWidth x _DestHeight _result in a value less than 10000, then the Crop Tool will use the aspect ration of the width/height vales, but the image will not be resized.
For example, a template designer may set the DestWidth and DestHeight to 16 and 9 to force an aspect ratio of 16:9. Instead of resizing the cropped image to a size of 16x9 pixels, it will use the size of the selection. For example, if we have the original image of 2000 x 1500 pixels, then:
  • If the template user selects an area of 800 x 450 pixels (16:9), the image will be cropped to 800 x 450 pixels. No resizing will occur.
