Viz Now LaunchPad
Version 1.2 | Published April 09, 2024 ©
TriCaster Now Live Panel
LivePanel allows users to create custom control panels for TriCaster, accessible through a web browser.
LivePanel also offers various production-ready tools for remote video mixing, media playback, audio mixing, and macro automation.
The launchpad will provide a simple way to log into the LivePanel using the pre-configured password for the Admin user.
Working with LivePanel
Prerequisites: Network Ports
Live Panel requires the opening of the following ports:
| Source | Destination | Protocol | Port |
| <client network> example: 192.168.0.0/24 | <Tricaster Now Public IP instance(s) > | TCP | 443 |
Opening Live Panel from Viz Now LaunchPad
To open LivePanel
-     Make sure the TriCaster application has started and that you have a production session in progress (that you have created a new session, or opened an existing one) before attempting to open the LivePanel from the LaunchPad.
-     Using the LaunchPad go to the OPEN menu and select Live Panel.
-     A new window appears hosting the LivePanel.
 The username and password can be retrieved from the top bar menu.
   -     Click each button to copy its value to the internal clipboard.
-     Right click on the correct field and select Paste.
-     Click Sign in when complete.
The LivePanel is now available.
Live Panel Credentials
 Do not update Live Panel credentials. These values are managed automatically by the system.
