Viz Multichannel
XML Translator
The XML Translator is a command-line tool for transforming a schedule-file in XML (BXF) format to a format Multichannel can import. Content is not changed, the tool just transforms data format so the Playlist Importer can process it.
Any third-party can define an XSLT (.xst) transformation to an importer-friendly structure, currently:
Ordered collections
Two (2) layers deep only
Installing the XML Translator
You can install XML translator with the bundle installer, for details see Bundle Installer in the Setup and Configuration chapter.
Alternatively, you can install the tool separately from the MSI installer:
Download the installer from ftp.vizrt.com or extract the MSI from the bundle installer.
Click VizMultichannel_XMLTranslator_VERSION.msi and follow the on-screen instructions.
Normally, the XML translator will be installed to:
%PROGRAMFILES%\Vizrt\Viz Multichannel\XMLTranslator\XMLTranslator.exe
Using the XML Translator
Open a command window (Windows-button+R CMD <enter>) to use the XML translator. If you need admin rights for any part when using the tool start CMD as Administrator then to start an elevated session, right-click CMD and select Run as Administrator. In the following we assume you have XML translator program in the Windows PATH, otherwise you will have to provide the full path to use the tool.
XMLTranslator.exe -SourcePath %path% -DestinationPath %dpath% -SuccessPath %spath% -FailPath %fpath% -TranslationFile %tpath%\XSL.xslt
The example invocation above is on one line. All arguments are required. To get usage instructions run the program with the help flag (-? or -h or):
XmlTranslator.exe –-help
Program argument definitions:
SourcePath the directory that contains the XML file to translate
DestinationPath a directory where the translated XML file is created in
SuccessPath a directory where the source XML file is moved to when translation succeeds
FailPath a directory where the source XML file is moved to if the translation fails
TranslationFile path to the XSL file defining the transformations
A typical run (the command should be entered on a single line) could be:
XMLTranslator.exe -SourcePath D:\Source -DestinationPath D:\Destination -SuccessPath D:\Success -FailPath D:\Fail -TranslationFile D:\BroadViewXML.xsl
Example invocation: help
Example invocation: success
Example invocation: fail
