Viz Multichannel
Clips
The Clips button opens up a search frame allowing you to search for video clips on Viz One. The search field allows you to use common search operators such as:
Search for a word: soccer
Search for an exact word or phrase: “world football championship”
Search for either word: soccer OR football
Search for both words: soccer AND football
Search using an asterisk (*) to “fill in the blanks”: foot*, *ball*, *ball
Clips Context Menu
Right-Click on Clips to show the context menu providing these options:
Refresh: Reload all clips from Viz One.
Deselect: Deselect a clip
Add to Clip Bank: add the selected Viz One clip into the Multichannel Clip Bank. You can select which clip bank tab the clip should be added to.
