Viz Multichannel
Scheduling
A typical installation includes one Viz Multichannel and a local Viz Engine. In addition you typically install Viz Multichannel’s Schedule Collector (SCC) and Playlist Importer (PLI) in order to collect and import playlists through mapping settings into Viz Multichannel.
Viz Engine is used for preview and is typically a VGA version without SDI out capabilities. This setup allows the Scheduling Center to prepare and preview playlists before sending them to playout by the program Viz Engine(s).
The following software components are in use:
Viz Multichannel client
Viz Multichannel’s Playlist Importer (PLI)
Viz Engine (local preview)
Media Sequencer
Installation for Scheduling
The machine in the Scheduling must have the following software components installed:
Media Sequencer
Viz Engine (preview)
IMPORTANT! Ensure that clocks on all machines in the installation are synchronized! It is also recommended to set all date formats on all machines to the same format.
To Install Viz Multichannel Client
Start the Viz Multichannel installer
Click Next
Select Complete and click Next
Select Custom if a different install path is needed. -
Click Install
Click Finish
To Install Media Sequencer
Start the Media Sequencer installer
Click Next
Click Next
Select features and/or a different install path if needed. -
Click Install
Put shortcuts on the desktop if needed. -
Click Finish
To Install Viz Engine
Viz Engine is used for local preview, hence, you only need to install a VGA version.
Start the Viz Artist/Viz Engine installer
Click Next
Check the I accept the terms in the License Agreement check box and click Next
Click VGA
Click Next
Click Install
Click Finish
Vizrt’s Documentation Center
