Viz Multichannel
Logging
Daily Log
For information and troubleshooting purposes there is a daily log file that provides details on every event that was played. The file is located on the Media Sequencer machine at: %ProgramData%\Vizrt\Media Sequencer. It is not set up as part of the installation process, hence, it must be created as part of the installation process described in the Playout section.
The logging file naming convention is ChannelName-YY-MM-DD.log. Each file includes the events played on that calendar day, which may not necessarily corresponds to a playlist. As such, the events in a playlist that starts at 7 AM and extends till the following day at 6 AM will be saved in two separate files, one for each calendar day.
Below is an example of a log file’s contents:
2007
12
18
12
06
36
: Running: read on /VizRundown/channels/AD/rundowns/21_11_2005_AD/data/PLAYLIST_DATA_ROMY_14_24_40_681_13_12_2007_823_IM_0
2007
12
18
12
06
41
2007
12
18
12
07
15
: Running: read on /VizRundown/channels/AD/rundowns/21_11_2005_AD/data/PLAYLIST_DATA_ROMY_12_06_58_663_18_12_2007_22_PA_0
2007
12
18
12
08
28
2007
12
18
12
09
34
2007
12
18
12
09
39
2007
12
18
12
09
46
2007
12
18
12
16
50
: Running: read on /VizRundown/channels/AD/rundowns/21_11_2005_AD/data/PLAYLIST_DATA_ROMY_14_24_40_759_13_12_2007_715_IM_2
2007
12
18
12
16
53
: Running: read on /VizRundown/channels/AD/rundowns/21_11_2005_AD/data/PLAYLIST_DATA_ROMY_12_16_29_344_18_12_2007_319_DR_0
2007
12
18
12
18
12
102
2007
12
18
12
18
17
102
As Run Logs
Daily log files in and of themselves are difficult to understand. However, you can submit them to log analysis to mine them for useful information.
In order to analyze the As Run logs you need to manually transfer the logs to your machine. The log directory on your remote Media Sequencer is set under the Logging section.
Each log entry contains the event date and time, template name, with the content of each template field.
If you want to perform simple analysis of your logs using Viz Multichannel you can use its built-in analysis tool.
Analyzing a Log
Start Viz Multichannel
Select Analyze Log from the Tools menu
Select your channel.
Select the from and to dates and click OK.
Select the log folder where you transferred the files to.
Click OK.
A log file is replicated with the same file name except it starts with Report-.
Standard Log Sample
Below is an example of a standard log file’s contents:
Date|Time|Action|Event Type|Description|Values
2013
05
31
14
03
57.970
:|take|Element|
1000
|Fields:
1
JSON Log Sample
Below is an example of a JSON log file’s content:
2006
10
06
23
29
34
: Template: START_SQUEEZE Fields:
30
: IMAGE*world_sports/swoosh
31
: IMAGE*YES_NEW/YesStars/Empty_Pic2
32
: IMAGE*YES_NEW/YesStars/Empty_Pic2 Header: Tonight IMG1: IMAGE*YES_NEW/YesStars/Empty_Pic IMG2: IMAGE*YES_NEW/YesStars/Empty_Pic IMG3: IMAGE*YES_NEW/YesStars/Empty_Pic Text1: Special Text2: aaaaaaaaaaaaa
2006
10
06
23
29
37
: Template: Top-Year Fields:
1
: <fo:wrapper scale-x=
"0"
><fo:wrapper scale-y=
"0"
1
</fo:wrapper></fo:wrapper><fo:wrapper scale-x=
"0"
"0"
9
"0"
"0"
9
"0"
"0"
2
2006
10
06
23
29
38
: Template: PURPLE_TOP_COMM_CLIP Fields: Text1: bla bla Text2: soccer wife Title1: help me Title2: today
22
00
comm_clip: ./dataclip/Dog.avi
2006
10
06
23
31
54
30
31
32
2006
10
06
23
32
26
30
31
32
2006
10
06
23
33
11
30
31
32
Channel and Playlist Reports
Channel and playlist reports can be created two ways; for a single channel and playlist or for multiple channels and playlists.
To Create a Report based on a Single Channel and Playlist
For information on how to set the Playlist Reports Folder, see the Miscellaneous section.
Click the Playlists button.
Right-click your playlist and from the appearing context menu select Generate Report.
An HTML report will open in your default browser.
To Create a Report based on Multiple Channels and Playlists
Select Tools from the main menu, and then Reports Manager.
From the Channels combo-box, select all the channels to run the report on.
Select the From and To dates to run the report on.
If desired, enable the From and To times with the check box, and select the times to run the report on.
Select the Path where the text file report will be saved. The default path used is %ProgramData%/Vizrt/Multichannel/Reports (i.e. normally C:\ProgramData\Vizrt/Multichannel/Reports) but if required you can select another location to use.
Click OK.
The resulting report looks as follows:
Channel|Date|Time|Event Type|Duration|Program|Template|Fields
Channel1|continuous|
2013
05
-29T12:
55
00.000
|Primary|
01
34
40
18
|Glory God is peeking through the blinds|
2013
05
-29T12:
55
00.000
|Secondary|
00
00
00
00
1000
|Bergen in snow
Multichannel Log Files
Multichannel and several multichannel components write log files when they run. The log files are ordinary textfiles and can be helpful for reporting or error detection and debugging.
The log files are written to the directory %PROGRAMDATA%\Vizrt\Multichannel
This will normally be: C:\ProgramData\Vizrt\Multichannel
Note that the \ProgramData directory normally is a Windows “hidden” directory so you will be required to explicit insert the directory name %PROGRAMDATA% in the address field in Windows Explorer to reach this directory.
Each Multichannel component (for instance PlayListImporter, Schedule Collector and so forth) will write it’s log files in a separate directory as documented below.
Warning: Care should be taken to set up automatic tasks or manual routines to “prune” or delete old log files that are no longer needed, otherwise the log files could eventually fill the disk.
Log File Locations
As explained above, all log files in the list below is relative to the log file base directory, so .\Logs means C:\ProgramData\Vizrt\MultiChannel\Logs
Multichannel: .\Logs
Harris Integration Module: .\HarrisIntegration
Pebble Beach Marina Integration Module: .\MarinaIntegration
%ProgramData%\Vizrt\Multichannel\PlaylistImporterV2
For 32 bit (legacy v1 setup): PlayListImporter: .\PlaylistImporter -
SCC Schedule Collector: .\ScheduleCollector
Playlist History Manager: .\PlaylistHistoryManager
Promo Server: No log-file on disk, use Windows Event Viewer.
Integrations Hub: No log-file on disk, use Windows Event Viewer.
ELF Log Dump Files
In case of program crash, ELF dump files can be created. ELF files are binary files, sometimes used by Vizrt support for debugging. If generated, the Elf file(s) will be created in:
%PROGRAMDATA%\Vizrt\Multichannel\Logs
%PROGRAMDATA%\Vizrt\Multichannel\PlaylistHistoryManager
%PROGRAMDATA%\Vizrt\Multichannel\PlaylistImporterV2
