Viz Multichannel
Generating the Channels File
Once you have finished all scheduling tasks, before proceeding to monitor your playlists in MCR mode, you should manually regenerate the channels file. It is essential that the IP addresses for the Remote Hosts have been properly configured per-channel in the General Settings.
To Regenerate channels.ini File
From the main menu select the Tools option
From the Tools menu click Generate Channels File.
You are prompted to allow Viz Multichannel to overwrite the existing file. -
Click Yes.
The channels file is normally located in C:\ProgramData\Vizrt\Multichannel and is named channels.ini. It is a normal text file and can be manually edited.
