Structure of MOS objects sent to NRCS
You can send Mosart templates as MOS objects to an NRCS and then use them to create items in a Viz Mosart rundown (as an alternative to the Mosart ActiveX method) as a brick system.
In addition to MOS objects that contain Viz Mosart templates, there is a special MOS object that can be sent containing lower thirds information.
This topic is covered in section Mosart Templates Feedback to the NRCS.
This section provides some sample MOS object files:
