Manus Administrator
Manus Administrator is the intelligent element of Viz Mosart, monitoring the rundown in the connected NRCS, parsing the content into Viz Mosart functionality that is presented in the Viz Mosart GUI.
Manus Administrator is a console application and must be kept running at all times on your Mosart server.
NRCS Software Compatibility
There are three versions of the Manus Administrator, corresponding to the flavor of newsroom system that it connects to.
The version choice is offered at initial Viz Mosart (server) installation:
(Default) Vizrt.Mosart.ManusAdministrator.exe. A combined iNEWS/MOS program.
MMConsoleAdmin_2007.exe. Only for iNEWS (with ftp) workflow.
MMConsoleAdmin_MOS.exe. Only for newsroom systems with MOS workflow.
Use for all systems except iNEWS with ftp workflow, including iNEWS with MOS workflow.
Only one Manus Administrator can be active at any given time.
Tip: Type help in the Manus Administrator console window to see which commands you can use. See Manus Administrator Commands.
See also Avid iNews Web Service for Status Feedback in the appendix.
Configuration Utilities
Manus Administrator Settings
From the Manus Administrator console you can open a configuration editor in a new window:
Type settings in the Manus Administrator console followed by ENTER.
From the first row General settings, select from NCS type.
Edit or reset values as needed.
Remember to click Save when ready.
For details see:
Settings Editor MOS as appropriate.
Newsroom Settings
To open the Newsroom Settings XML Editor, type ns in the console window followed by ENTER. For details see:
Note: The Newsroom Settings editor opens in a new window. If you make changes to the configuration, restart Manus Administrator for the changes to be applied.
The rest of this section covers these topics:
