Note: As a general recommendation for all hardware types:
Disable all power saving options in Windows or in the BIOS Settings.
Disable Hibernate mode.
Disable Secure boot for driver installations (optional).
The installation of video, audio or graphics cards, is not required on a new system. However, for maintenance or upgrades, it is important to know how to install the different models.
This section describes the all supported systems and their configuration supported by Viz Engine.
IMPORTANT! Any other setup than those described is not guaranteed to be supported by Vizrt and may cause problems during operation.
Note: Vizrt may make changes to specifications and product descriptions at any time, without notice.
- HP Z4 G5
- HP Z4 Rack G5
- HP Z8 G5 Fury
- Lenovo P3 Ultra / P3 Ultra Gen 2
- Lenovo P620
- Lenovo SR655 V3
- HP Z4 G6i
- HP Z8 Fury G6i
All machines ordered from Vizrt are pre-installed and do not require any changes. the following table list the current installation base:
Machine | OS | GPU |
HP Z4 G5 | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2 | Ampere, Ada, Blackwell |
HP Z4 G5 Rack | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2 | Ampere, Ada, Blackwell |
HP Z8 G5 Fury | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2 | Ampere, Ada, Blackwell |
Lenovo P620 | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2 | Ampere, Ada, |
Lenovo P3 Ultra | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2 | Ada 2000 or 4000SFF |
Lenovo P3 Ultra Gen2 | Windows 11 LTSC IoT 24H2 | Ada 2000 or 4000SFF |
Lenovo SR655 V3 | Windows 10 LTSC IoT 21H2, Windows 11 LTSC IoT 24H2, Windows Server 2022, | Ampere, Ada, Blackwell |
Z4 G6i | Windows 11 LTSC IoT 24H2 | Blackwell |
Z8 Fury G6i | Windows 11 LTSC IoT 24H2 | Blackwell |
