Slot/Card Installation
Slot Configuration
Slot | Usage |
Slot 1 Gen5 x16 | Graphics Card |
Slot 2 Gen4 x8 (PCH) | Free or used by Dual Slot GPU |
Slot 3 Gen4 x8 (PCH) | Other Expansion Card (Serial, GPI) |
Slot 4 Gen4 x16 | Matrox Video Card (X.mio5, DSX LE5) |
Slot 5 Gen4 x16 | Other Expansion Card (Serial, GPI) |
Default Hardware
Single CPU 10-Cores
Power Supply: 1000W Platinum
PCIe Gen4+Gen5 Slots
5 PCIe Slots
64GB DDR5 1x512GB M.2 + 1x 1TB M.2
1x Gbit RJ45 onboard
1x 10Gbit RJ45 Flex IO
OS Support:
Windows 10 LTSC 2021
Windows 11 LTSC 2024
GPU Support:
Nvidia Ampere: RTX A2000, RTX A4000, RTX A5000, RTX A6000
Nvidia Ada: RTX 2000 Ada, RTX 4000 Ada, RTX 5000 Ada, RTX 6000 Ada
Nvidia Blackwell: RTX PRO 2000 Blackwell, RTX PRO 4000 Blackwell, RTX PRO 5000 Blackwell, RTX PRO 6000 Blackwell Max-Q (300W)
Matrox Support: XMIO5, DSXLE5
Bios Settings
Security/Secure Boot Configuration Secure Boot: Enable
Advanced/Built-In Device Options:
Increase PCIe Idle Fan Speed(%): 30
Advanced/Power Management Options:
Hardware P-States: Disable
S4/S5 Maximum Power Savings: Disable
PCI Express Power Management: Disable
Advanced/Performance Options:
Workload Configuration: I/O-Focused
